Datasheet Texas Instruments TLV2252QD — Даташит
СерияTLV2252
МодельTLV2252QD
Двойной низковольтный операционный усилитель малой мощности Rail-To-Rail 8-SOIC от -40 до 125
Advanced LinCMOS Rail-to-Rail Very Low-Power Op Amps Very Low-Power Operational datasheet
PDF, 2.1 Мб, Версия: D, Файл опубликован: 12 авг 2006
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesHigh Cload Drive
Approx. Price (US$)0.73 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)70
CMRR(Typ)(dB)83
GBW(Typ)(MHz)0.2
Input Bias Current(Max)(pA)60
Iq per channel(Max)(mA)0.0625
Iq per channel(Typ)(mA)0.035
Number of Channels(#)2
Offset Drift(Typ)(uV/C)0.5
Operating Temperature Range(C)-40 to 125
0 to 70
Output Current(Typ)(mA)8
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)0.12
Total Supply Voltage(Max)(+5V=5, +/-5V=10)8
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)19
Vos (Offset Voltage @ 25C)(Max)(mV)1.5
RoHSНе совместим
  • Solid State Voice Recorder Using Flash MSP430
    PDF, 101 Кб, Файл опубликован: 25 янв 2001
    The promise of cost-effective re-programmable MSP430 MCU systems has recently come to fruition with the integration of In-System Programmable (ISP) flash memory. Firmware delivered just in time during manufacturing, updateable code in field-deployed systems, and the elimination of discrete EEPROMs are now design realities. This application report demonstrates the flexibility of in-system programma
На английском языке: Datasheet Texas Instruments TLV2252QD
