Datasheet Texas Instruments UCC2891DR — Даташит
СерияUCC2891
МодельUCC2891DR
ШИМ-контроллер с активным ограничением тока в режиме тока 16-SOIC от -40 до 85
UCC289x Current Mode Active Clamp PWM Controller datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 1 июл 2009
Pin16
Package TypeD
Package QTY2500
МаркировкаUCC2891
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodCurrent
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Gate Drive(Typ)2.5 A
Special FeaturesHV Start-up,Input Line Monitor,Multi-topology,Programmable Slope Compensation,Soft Start,Soft Switching
TopologyActive-Clamp Forward,Flyback,Forward
UVLO Thresholds On/Off13.0/8.0 В
Vin(Max)110 В
Vin(Min)18 В
  • Evaluation Modules & Boards: UCC2891EVM-520
    Evaluation Module for UCC2891 Current Mode Active Clamp PWM Controller
  • Design of a 60-A interleaved active-clamp forward converter
    PDF, 192 Кб, Файл опубликован: 22 янв 2013
  • Active Clamp Transformer Reset: High Side or Low Side?
    PDF, 167 Кб, Файл опубликован: 17 сен 2004
  • 1Q 2013Issue Analog Applications Journal
    PDF, 1.1 Мб, Файл опубликован: 22 янв 2013
  • Understanding and Designing an Active Clamp Current Mode Controlled Converter
    PDF, 845 Кб, Файл опубликован: 6 май 2010
    The UCC2897A Current Mode Active Clamp PWM Controller offers a highly integrated feature set resulting in precision control required for an active clamp forward or flyback converter. The UCC2897A data sheet contains all the design details necessary for accurately programming the device. However, there are significant design considerations and trade-offs unique to the active clamp power stage that
  • Method of Providing Hiccup Operation for UCC2897AEVM
    PDF, 361 Кб, Файл опубликован: 27 авг 2009
    This application note is to provide users of the UCC2897AEVM with a method of generating acyclic restart or restart attempt of the EVM should the converter encounter an overcurrent condition including an output short.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC2891DR
