Datasheet Texas Instruments OPA2690I-14DR — Даташит
СерияOPA2690
МодельOPA2690I-14DR
Двойной широкополосный операционный усилитель с обратной связью по напряжению и отключением 14-SOIC от -40 до 85
Dual, Wideband, Voltage-Feedback Operational Amplifier with Disable datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 4 мар 2010
Pin14
Package TypeD
Package QTY2500
МаркировкаOPA2690
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic68 dBc
3rd Harmonic70 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Voltage FB
BW @ Acl500 МГц
CMRR(Min)60 дБ
CMRR(Typ)65 дБ
GBW(Typ)500 МГц
Input Bias Current(Max)11000000 pA
Iq per channel(Max)5.8 мА
Iq per channel(Typ)5.5 мА
Количество каналов2
Offset Drift(Typ)12 uV/C
Output Current(Typ)190 мА
Rail-to-RailNo
Slew Rate(Typ)1800 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)5.5 нВ/rtГц
Vn at Flatband(Typ)5.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4.5 мВ
  • Evaluation Modules & Boards: DEM-OPA-SO-2D
    DEM-OPA-SO-2D
  • Evaluation Modules & Boards: DEM-OPA268XN
    DEM-OPA268xN: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Op Amp Performance Analysis
OPA2690I14DR, OPA2690I 14DR
На английском языке: Datasheet Texas Instruments OPA2690I-14DR
