Datasheet Texas Instruments TLV2460AQPWR — Даташит
СерияTLV2460A
МодельTLV2460AQPWR
Одиночный, маломощный, Rail-to-Rail операционный усилитель ввода/вывода с отключением 8-TSSOP от -40 до 125
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesShutdown
Approx. Price (US$)0.95 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)71
CMRR(Typ)(dB)85
GBW(Typ)(MHz)6.4
Input Bias Current(Max)(pA)14000
Iq per channel(Max)(mA)0.65
Iq per channel(Typ)(mA)0.55
Number of Channels(#)1
Offset Drift(Typ)(uV/C)2
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)60
Package GroupPDIP
SOIC
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)1.6
Total Supply Voltage(Max)(+5V=5, +/-5V=10)6
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)11
Vos (Offset Voltage @ 25C)(Max)(mV)1.5
RoHSНе совместим
  • Using the TLV246x as a Multiplexer with Gain in a Data Acquisition System
    PDF, 62 Кб, Файл опубликован: 14 дек 1998
    Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters.
  • TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
На английском языке: Datasheet Texas Instruments TLV2460AQPWR
