Datasheet Texas Instruments LMH6624MFX/NOPB — Даташит
СерияLMH6624
МодельLMH6624MFX/NOPB
Одиночный/двойной широкополосный операционный усилитель со сверхмалым шумом 5-SOT-23 от -40 до 125
LMH6624 and LMH6626 Single/Dual Ultra Low Noise Wideband Operational Amplifier datasheet
PDF, 1.9 Мб, Версия: G, Файл опубликован: 19 дек 2014
16 предложений от 16 поставщиков
Рутоника
LMH6624MFX/NOPB
162 ₽
Зенер
Россия и страны ТС
LMH6624MFX/NOPB
681 ₽
МосЧип
LMH6624MFX/NOPB
LMH6624MFX/NOPB
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаA94A
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesDecompensated
АрхитектураBipolar
CMRR(Min)87 дБ
CMRR(Typ)95 дБ
GBW(Typ)1800 МГц
Input Bias Current(Max)20000000 pA
Iq per channel(Max)16 мА
Iq per channel(Typ)12 мА
Количество каналов1
Offset Drift(Typ)0.25 uV/C
Output Current(Typ)100 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailNo
Slew Rate(Typ)400 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)0.92 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Evaluation Modules & Boards: LMH730227
    Evaluation Board for High-Speed Single Op Amp in the 8-Pin SOIC Package
  • Evaluation Modules & Boards: LMH730216
    Evaluation Board for High-Speed Single Op Amp in the 5- 6-Pin SOT-23 Package
  • Evaluation Modules & Boards: LMH730316
    LMH730316 Evaluation Board for High-Speed Single Op Amp in the 5-/6-Pin SOT-23 Package
  • AN-1604 Decompensated Operational Amplifiers (Rev. B)
    PDF, 206 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application report discusses the what, why, and where of decompensated op amps. This applicationreport also describes external compensation techniques, such as reducing loop gain, to stabilize op ampsoperated at gains less than the minimum stable gain specified in the datasheet. A comprehensivetreatment of input lead-lag compensation including examples is presented.
  • OA-14 Improving Amplifier Noise for High 3rd Intercept Amplifiers (Rev. F)
    PDF, 594 Кб, Версия: F, Файл опубликован: 1 май 2013
    This application report discusses improving Amplifier Noise for High 3rd Intercept Amplifiers.
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
  • OA-15 Frequent Faux Pas in Applying Wideband Current Feedback Amplifiers (Rev. C)
    PDF, 365 Кб, Версия: C, Файл опубликован: 17 апр 2013
    As op amp operating speeds have moved to ever higher frequencies, a whole new set of design concernshave come into play for linear op amp applications. With the development of the current feedbacktopology, design concerns unique to that topology must also be considered if optimal performance is to beachieved from devices offering over 200 MHz в€’3 dB bandwidths. This application report reviews
На английском языке: Datasheet Texas Instruments LMH6624MFX/NOPB
