Клеммники KEEN SIDE
Datasheet Texas Instruments TPS61158DRVR — Даташит
СерияTPS61158
МодельTPS61158DRVR
Драйвер WLED 30 В со встроенным силовым диодом 6-WSON от -40 до 85
TPS61158 30-V WLED Driver with Integrated Power Diode datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 18 июн 2015
45 предложений от 19 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
TPS61158DRVR
35 ₽
TPS61158DRVR
37 ₽
Элитан
TPS61158DRVR
81 ₽
TPS61158DRVR
110 ₽
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаSIW
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
Количество каналов1
Duty Cycle(Max)94 %
LED8
LED Current Per Channel30 мА
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Peak Efficiency94 %
Shutdown Current(Typ)1 uA
Special FeaturesEnable/Shutdown,OVP,PWM Control,Soft Start,Thermal Shutdown
Switching Frequency(Max)960 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)29 В
Vout(Min)2.7 В
  • Simple Backlight Driver Dimming Performance
    PDF, 74 Кб, Файл опубликован: 20 мар 2017
    The TPS61158, TPS61160/61, TPS61162/63A, TPS61165, and TPS61169 (hereafter TPS611xx) are simple backlight drivers commonly used in smartphones and tablets. These devices support PWM dimming with an input voltage as low as 2.7 V. This application note discusses the requirements for using tje TPS611xx parts at the lowest performance specifications for PWM dimming.
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: TPS61158 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61158DRVR
