Datasheet Texas Instruments TPS62240DRVR — Даташит
СерияTPS62240
МодельTPS62240DRVR
Понижающий преобразователь 2,25 МГц, 300 мА в корпусе SON/TSOT23 2x2 мм, 6-WSON от -40 до 85
TPS6224x 2.25-MHz 300-mA Step-Down Converter in 2 x 2 WSON and SOT Package datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 31 июл 2015
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаBYJ
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)0.3 A
Iq(Typ)0.015 мА
Package GroupWSON
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Synchronous Rectification
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)2000 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2 В
Vout(Max)6 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS62260LED-338
    TPS62260LED-338 Evaluation Module
  • Evaluation Modules & Boards: TPS62240EVM-229
    TPS62240 6V Input, 1.8V Output, 0.3A Evaluation Module
  • Evaluation Modules & Boards: TMDSPLCKITV4-CEN
    Power Line Communications Kit for CENELEC Frequency Band
  • High-Efficiency Power Solution Using DC/DC Converter For TMS320C2834x MCU
    PDF, 138 Кб, Файл опубликован: 28 июл 2009
    This reference design is intended for users designing with the TMS320C2834x microcontrollers. This design, employing sequenced power supplies, describes a system with an input voltage of 5 V and uses high-efficiency DC/DC converters with integrated FETs for a simple, small design.
  • TMS320DM355 DSP Power Reference Design PR742 (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 8 авг 2008
    This reference design is for the TMS320DM335/DM355 digital signal processor (DSP) and accounts for voltage, current, and sequencing requirements. The operating input voltage ranges from 2 V to 5.5 V for Li-ion batteries and 3 AA batteries. This design also can work with 2 AA batteries with some limitations. The design is optimized for efficiency over the full range of operation and low overall cos
  • 2Q 2012 Issue Analog Applications Journal
    PDF, 2.4 Мб, Файл опубликован: 26 апр 2012
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
На английском языке: Datasheet Texas Instruments TPS62240DRVR
