Datasheet Texas Instruments LM2852XMXA-1.5 — Даташит
СерияLM2852
МодельLM2852XMXA-1.5
2A 500/1500kHz Synchronous SIMPLE SWITCHERВ® Buck Regulator 14-HTSSOP -40 to 125
LM2852 2A 500/1500 kHz Synchronous Buck Regulator datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 6 янв 2016
45 предложений от 21 поставщиков
LM2852XMXA-1.5/NOPB
от 67 ₽
LM2852XMXA-1.5
81 ₽
Зенер
Россия и страны ТС
LM2852XMXA-1.5/NOPB
от 237 ₽
LM2852XMXA-1.5/NOPB
Pin1414
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Маркировка1.52852X
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Рекомендуемая замена
ReplacementLM2852XMXA-1.5/NOPB
Replacement CodeS
Approx. Price (US$)1.58 | 1ku
Control ModeVoltage Mode
Duty Cycle(Max)(%)100
Iout(Max)(A)2
Iq(Typ)(mA)0.85
Operating Temperature Range(C)-40 to 125
Package GroupHTSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Synchronous Rectification
Tracking
Switching Frequency(Max)(kHz)1500
Switching Frequency(Min)(kHz)500
ТипConverter
Vin(Max)(V)5.5
Vin(Min)(V)2.85
Vout(Max)(V)3.3
Vout(Min)(V)0.8
RoHSНе совместим
  • Evaluation Modules & Boards: LM2852Y-2.5EVAL
    2A 500 1500kHz Synchronous SIMPLE SWITCHERВ® Buck Regulator Evaluation Module
  • Evaluation Modules & Boards: LM2852X-2.5EVAL
  • Evaluation Modules & Boards: LM2852X-3.3EVAL
    2A 500 1500kHz Synchronous SIMPLE SWITCHERВ® Buck RegulatorEvaluation Module
  • Evaluation Modules & Boards: LM2852Y-1.2EVAL
  • Evaluation Modules & Boards: LM2852Y-3.3EVAL
  • Evaluation Modules & Boards: LM2852Y-1.8EVAL
  • Evaluation Modules & Boards: LM2852X-1.8EVAL
  • Evaluation Modules & Boards: LM2852X-1.2EVAL
  • Power Management Design for Applications Processors
    PDF, 559 Кб, Файл опубликован: 22 мар 2007
  • AN-1821 CPRI Repeater System (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report implements the Common Public Radio Interface (CPRI) for Remote Radio Heads(RRHs). The designer can use this application report for developing CPRI-based repeater systems inpoint-to-point or multi-hop configurations. This application report consists of:Designs for the CPRI SerDes Repeater Boards for the Radio Equipment (RE) and Radio EquipmentController (REC)
LM2852XMXA1.5, LM2852XMXA 1.5
На английском языке: Datasheet Texas Instruments LM2852XMXA-1.5
