Datasheet Texas Instruments LM92CIMX — Даташит
СерияLM92
МодельLM92CIMX
В±0.5В°C Temperature Sensor with Alert Function and I2C/SMBus Interface 8-SOIC -55 to 150
12-Bit + Temp Sensor & Thermal Window Comparator w/2-Wire Interface datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 22 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM92CIM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM92CIMX/NOPB
Replacement CodeS
Addresses4
Approx. Price (US$)1.93 | 1ku
InterfaceI2C
SMBus
2-Wire
Iq(Typ)(uA)350
Local Sensor Accuracy(Max)(+/- C)0.5
Operating Temperature Range(C)-55 to 150
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Special FeaturesProgrammable Alert
Fault Queue
Window Comparator
Shutdown
Supply Current(Max)(uA)625
Supply Current(Typ)(uA)350
Supply Voltage(Max)(V)5.5
Supply Voltage(Min)(V)2.7
Temp Resolution(Max)(bits)13
RoHSTBD
  • Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)
    PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
    This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
Серия: LM92 (4)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments LM92CIMX
