Datasheet Texas Instruments TPS54880PWPG4 — Даташит
СерияTPS54880
МодельTPS54880PWPG4
4.5 to 5.5V Input, 8A Synchronous Step-Down Converter for SequencingВ  28-HTSSOP -40 to 85
4-V to 6-V Input, 8-A Output Tracking Synchronous Buck PWM Switcher datasheet
PDF, 764 Кб, Версия: A, Файл опубликован: 15 апр 2005
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS54880
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)8 A
Iq(Typ)11 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Power Good,Synchronous Rectification,Tracking
Switching Frequency(Max)700 kHz
Switching Frequency(Min)280 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)4 В
Vout(Max)3.3 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Evaluation Modules & Boards: TPS54880EVM
    8-A DC/DC Converter with Simultaneous Sequencing of Multiple Voltages
  • Using TPS54x80 Tracking SWIFT(TM) dc/dc Converters f/Simult. Tkg of Input Supply
    PDF, 115 Кб, Файл опубликован: 10 фев 2005
    High-performance signal processing devices, such as FPGAs and DSPs, require multiple power supply voltages for operation. The order and timing in which these supply outputs power up and down is usually specified. A design example using the TPS54380 is shown for the case where the power supply to be tracked is also the input voltage to the TPS54380. Information is provided for adjusting the start-u
  • Power Ref Design for TMS320C6472 5Vin DC/DC Converters (1x C6472)
    PDF, 251 Кб, Файл опубликован: 31 мар 2010
    This reference design is intended for designers who wish to design a TMS320C6472 Digital Signal Processor into a system using a nominal input voltage of 5 V, DC/DC converters with integrated FETs, and allowing for ease-of-design and a smaller solution size.
  • Sequencing with TPS54x80 and TPS54x73 DC/DC Converters
    PDF, 169 Кб, Файл опубликован: 14 апр 2003
    Design of a power supply for a high-performance point-of-load processor requires special attention to manage core and input/output (I/O) voltage sequencing, which is critical to device operation and long term reliability. The TPS54x80 devices of low input voltage synchronous-buck dc/dc converters are designed for easily implementing sequential, ratio-metric, or simultaneous sequencing schemes. F
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54880 (3)
На английском языке: Datasheet Texas Instruments TPS54880PWPG4
