Datasheet Texas Instruments LM393PSLE — Даташит
СерияLM393
МодельLM393PSLE
Двойной дифференциальный компаратор 8-SO от 0 до 70
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
ИС, компараторы Dual Differential
ТаймЧипс
LM393PSLE(EIAJ)
LM393PSLE
LM393PSLE
LM393PSLE
Package TypePS
Industry STD TermSOP
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.07 | 1ku
Input Bias Current (+/-)(Max)(nA)50
Iq per channel(Max)(mA)0.5
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
0 to 70
Тип выходаOpen Collector
Package GroupSO
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)(V)34.5
Vos (Offset Voltage @ 25C)(Max)(mV)5
Vs(Max)(V)36
Vs(Min)(V)2
tRESP Low - to - High(us)0.3
RoHSНе совместим
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM393PSLE
