Линейка продуктов KEEN SIDE
Datasheet Texas Instruments OPA830IDBVR — Даташит
СерияOPA830
МодельOPA830IDBVR
Маломощный операционный усилитель с однополярным питанием 5-SOT-23 от -40 до 85
Low-Power, Single-Supply, Wideband Operational Amplifier datasheet
PDF, 843 Кб, Версия: F, Файл опубликован: 28 авг 2008
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаA72
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic67 dBc
3rd Harmonic60 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl310 МГц
CMRR(Min)76 дБ
CMRR(Typ)80 дБ
GBW(Typ)310 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)4.7 мА
Iq per channel(Typ)4.25 мА
Количество каналов1
Offset Drift(Typ)25 uV/C
Output Current(Typ)80 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)600 V/us
Total Supply Voltage(Max)11 +5V=5, +/-5V=10
Total Supply Voltage(Min)2.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)9.5 нВ/rtГц
Vn at Flatband(Typ)9.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)7 мВ
  • Evaluation Modules & Boards: DEM-OPA-SOT-1A
    Unpopulated PCB Compatible w/High Speed, Wide Bandwidth Op Amps in SOT(DBV) Pkg
  • Evaluation Modules & Boards: DEM-OPA-SO-1A
    DEM-OPA-SO-1A Unpopulated PCB Compatible w/High Speed Wide Bandwidth Op Amps in 8-lead SOIC (D) Pkg
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
На английском языке: Datasheet Texas Instruments OPA830IDBVR
