Datasheet Texas Instruments 66AK2H12BAAWA2 — Даташит
Серия66AK2H12
Модель66AK2H12BAAWA2
Многоядерная однокристальная система DSP+ARM KeyStone II (SoC) 1517-FCBGA от -40 до 100
66AK2Hxx Multicore DSP+ARMВ® KeyStone II System-on-Chip (SoC) datasheet
PDF, 2.4 Мб, Версия: F, Файл опубликован: 2 июн 2017
Цифровой сигнальный процессор DSP, DSP Fixed-Point/Floating-Point 1517Pin FCBGA Tray
66AK2H12BAAWA2
46 762 ₽
Рутоника
66AK2H12BAAWA2
66AK2H12BAAWA2
727GS
66AK2H12BAAWA2
Pin151715171517
Package TypeAAWAAWAAW
Package QTY212121
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка66AK2H12AAW@2012 TIA1.2GHZ
Width (мм)404040
Length (мм)404040
Thickness (мм)3.073.073.07
ARM CPU4 ARM Cortex-A15
ARM MHz1200,1400 Max.
ApplicationsAutomation and Process,Avionics and Defense,Communications and Telecom,Consumer Electronics,Industrial,Medical,Security,Space
DRAMDDR3,DDR3L
DSP8 C66x
DSP MHz1200 Max.
EMAC4-port 1Gb Switch
Hardware AcceleratorsPacket Accelerator,Security Accelerator
I2C3
On-Chip L2 Cache4096 KB (ARM Cluster),1024 KB (per C66x DSP core)
Operating SystemsIntegrity,Linux,SYS/BIOS,VxWorks
Рабочий диапазон температурот -40 до 100,0 до 85 C
Other On-Chip Memory6144 KB
PCI/PCIe2 PCIe Gen2
SPI3
UART2 SCI
USB1
  • Evaluation Modules & Boards: EVMK2H
    66AK2H Evaluation Modules
    XDS200 USB Debug Probe
  • Power Consumption Summary for 66AK2Hx System-on-Chip (SoC) Device Family
    PDF, 47 Кб, Файл опубликован: 28 сен 2017
    This application report discusses estimating the power consumption of Texas Instruments' K2Hx Digital Signal Processors (DSP) using a provided device-specific power spreadsheet. Note that the power model is applicable for all silicon revisions.
  • Keystone EDMA FAQ
    PDF, 1.3 Мб, Файл опубликован: 1 сен 2016
    This document is a collection of frequently asked questions (FAQs) on enhanced direct memory access (EDMA) on KeyStoneв„ў I (KS1) and KeyStone II (KS2) devices, along with useful collateral and software reference links.
  • Keystone NDK FAQ
    PDF, 54 Кб, Файл опубликован: 3 окт 2016
    This document is a collection of frequently asked questions (FAQ) on running the NDK examples on the KeyStoneв„ў family of devices.
  • Throughput Performance Guide for KeyStone II Devices (Rev. B)
    PDF, 866 Кб, Версия: B, Файл опубликован: 22 дек 2015
    This application report analyzes various performance measurements of the KeyStone II family of processors. It provides a throughput analysis of the various support peripherals to different end-points and memory access.
  • Keystone II DDR3 Debug Guide
    PDF, 143 Кб, Файл опубликован: 16 окт 2015
    This guide provides tools for use when debugging a failing DDR3 interface on a KeyStone II device.
  • Power Management of KS2 Device (Rev. C)
    PDF, 61 Кб, Версия: C, Файл опубликован: 15 июл 2016
    This application report lists the steps to enable Class 0 Temperature Compensation (Class 0 TC) mode of SmartReflexв„ў Subsystem (SRSS) module available on such devices.
  • Keystone II DDR3 Initialization
    PDF, 73 Кб, Файл опубликован: 26 янв 2015
    This application report provides a step-to-step initialization guide for the Keystone II device DDR3 SDRAM controller.
  • Hardware Design Guide for KeyStone II Devices
    PDF, 1.8 Мб, Файл опубликован: 24 мар 2014
  • SERDES Link Commissioning on KeyStone I and II Devices
    PDF, 138 Кб, Файл опубликован: 13 апр 2016
    The serializer-deserializer (SerDes) performs serial-to-parallel conversions on data received from a peripheral device and parallel-to-serial conversion on data received from the CPU. This application report explains the SerDes transmit and receive parameters tuning, tools and some debug techniques for TI Keystone I and Keystone II devices.
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • Processor SDK RTOS Audio Benchmark Starter Kit
    PDF, 530 Кб, Файл опубликован: 12 апр 2017
    The TI TMS320C6000в„ў Digital Signal Processors (DSPs) have many architectural advantages that make them ideal for computation-intensive real-time applications that are commonly used in audio processing application. This application notes describes Audio Benchmark Starterkit software that is intended to provide an easy and quick way to benchmark key audio functions on C66x and C674x DSP device
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP + ARM Processors > 66AK2x
На английском языке: Datasheet Texas Instruments 66AK2H12BAAWA2
