Datasheet Texas Instruments V62/06650-01XE — Даташит
СерияDAC5687-EP
МодельV62/06650-01XE
Усовершенствованный продукт, двухканальный, 16-разрядный, 500 MSPS, интерполяционный цифро-аналоговый преобразователь 1x-8x 100-HTQFP от -55 до 125
16-Bit 500 MSPS 2x-8x Interpolating Dual-Channel DAC datasheet
PDF, 2.2 Мб, Файл опубликован: 1 июн 2006
Pin100
Package TypePZP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (10+1)
МаркировкаDAC5687MPZPEP
Width (мм)14
Length (мм)14
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
АрхитектураCurrent Sink
DAC Channels2
DNL(Max)3 +/-LSB
INL(Max)6 +/-LSB
InterfaceParallel CMOS
Output Range Max.20 мА
Output Range Min.2 мА
Тип выходаCurrent
Package GroupHTQFP
Package Size: mm2:W x L100HTQFP: 256 mm2: 16 x 16(HTQFP) PKG
Power Consumption(Typ)1410 mW
RatingHiRel Enhanced Product
Reference: TypeInt
Разрешение16 Bits
SFDR80 дБ
SNR75 дБ
Sample / Update Rate500 MSPS
Время установления0.012 µs
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
Серия: DAC5687-EP (2)
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
V62/0665001XE, V62/06650 01XE
На английском языке: Datasheet Texas Instruments V62/06650-01XE
Публикации по теме
