Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVC08D — Даташит
СерияSN74LVC08
МодельSN74LVC08D
Четверной 2-входовой логический элемент «И» 14-SOIC от -40 до 85
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementSN74LVC08AD
Replacement CodeQ
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC08 (4)
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments SN74LVC08D
