Datasheet Texas Instruments REG113NA-2.5/250G4 — Даташит
СерияREG113
МодельREG113NA-2.5/250G4
400 мА, малошумящий регулятор с малым падением напряжения 5-SOT-23 от -40 до 85
DMOS 400mA Low-Dropout Regulator datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 8 сен 2005
Чип стабилизации напряжения, LDO Regulator Pos 2.5V 0.4A 5Pin SOT-23 T/R
REG113NA-2.5/250G4
52 ₽
REG113NA-2.5/250G4
170 ₽
LifeElectronics
REG113NA-2.5/250G4
REG113NA-2.5/250G4
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаR13G
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Точность3 %
Fixed Output Options2.5,2.85,3,3.3,5 В
Iout(Max)0.4 A
Iq(Typ)0.4 мА
Noise28 uVrms
Output Capacitor TypeCap Free,Ceramic
Output OptionsFixed Output
PSRR @ 100KHz28 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Special FeaturesEnable,Foldback Overcurrent Protection
Thermal Resistance ОёJA160 В°C/W
Vdo(Typ)250 мВ
Vin(Max)10 В
Vin(Min)2.7 В
Vout(Max)5 В
Vout(Min)2.5 В
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG113NA2.5/250G4, REG113NA 2.5/250G4
На английском языке: Datasheet Texas Instruments REG113NA-2.5/250G4
