Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LMR64010XMFX/NOPB — Даташит
СерияLMR64010
МодельLMR64010XMFX/NOPB
SIMPLE SWITCHER® Повышающий стабилизатор от 2,7 до 14 В, 1 А в корпусе SOT-23 5-SOT-23 от -40 до 125
LMR64010 SIMPLE SWITCHER ® 40Vout, 1A Step-Up Voltage Regulator in SOT-23 datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 4 апр 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаSF9B
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Duty Cycle(Max)93 %
Iq(Typ)2.1 мА
Package GroupSOT-23
Regulated Outputs1
Special FeaturesEnable
Switch Current Limit(Min)1 A
Switch Current Limit(Typ)1.5 A
Switching Frequency(Max)1600 kHz
Switching Frequency(Min)1600 kHz
ТипConverter
Vin(Max)14 В
Vin(Min)2.7 В
Vout(Max)40 В
Vout(Min)3 В
  • Evaluation Modules & Boards: LMR64010XMFDEMO
    LMR64010 SIMPLE SWITCHERВ® 40Vout, 1A Step-Up Regulator in SOT-23 Demo Board
  • Design of UVLO for LM27313 (Rev. B)
    PDF, 142 Кб, Версия: B, Файл опубликован: 8 апр 2014
  • Working With Boost Converters
    PDF, 159 Кб, Файл опубликован: 15 июн 2015
    This brief note highlights some of the more common pitfalls when using boost regulators. These includemaximum achievable output current and voltage, short circuit behavior and basic layout issues. It isassumed that the reader is familiar with the basic operation of a boost regulator.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Inverted SEPIC Made SIMPLE
    PDF, 408 Кб, Файл опубликован: 31 июл 2015
    There can be quite a few applications that require a conversion from a negative input voltage to a negativeoutput voltage and there are a few ways to go about doing it. The telecom industry is one such examplewhere the rails are usually negative. This design space along with being limited is not well explored. In thisapplication note we will go over the use of an integrated boost regulator i
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
Серия: LMR64010 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LMR64010XMFX/NOPB
