Datasheet Texas Instruments DAC707KP-BI — Даташит
СерияDAC707
МодельDAC707KP-BI
Datasheet
TSP
Pin28
Package TypeNTD
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)13.525
Length (мм)37.4
Thickness (мм)4.07
Pitch (мм)2.54
Max Height (мм)6.35
Рекомендуемая замена
ReplacementDAC7741Y/250
Replacement CodeP
RoHSНе совместим
  • Superposition: The Hidden DAC Linearity Error
    PDF, 106 Кб, Файл опубликован: 2 окт 2000
    A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog output voltages or currents. When the contribution to the output voltage or current of each individual bit is independent of any other, it means that the device exhibits no superposition error or tha
Серия: DAC707 (7)
  • Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
DAC707KPBI, DAC707KP BI
На английском языке: Datasheet Texas Instruments DAC707KP-BI
