Datasheet Texas Instruments XDM3730CBP — Даташит
СерияDM3730
МодельXDM3730CBP
Цифровой медиапроцессор 515-POP-FCBGA от 0 до 90
DM3730, DM3725 Digital Media Processors datasheet
PDF, 3.3 Мб, Версия: D, Файл опубликован: 11 апр 2011
Pin515
Package TypeCBP
Industry STD TermPOP-FCBGA
JEDEC CodeS-PBGA-N
Width (мм)12
Length (мм)12
Thickness (мм).5
Pitch (мм).4
Max Height (мм).7
ARM CPU1 ARM Cortex-A8
ARM MHz (Max.)800
1000
ApplicationsAudio
Automotive
Communications and Telecom
Computers and Peripherals
Consumer Electronics
Energy
Industrial
Medical
Security
Approx. Price (US$)25.60 | 1ku
DRAMLPDDR
DSP1 C64x
DSP MHz (Max.)660
800
I2C4
On-Chip L2 Cache256 KB (ARM Cortex-A8)
Operating SystemsAndroid
DSP/BIOS
Neutrino
ntegrity
Windows Embedded CE
Linux
VXWorks
Operating Temperature Range(C)-40 to 105
-40 to 90
0 to 90
Pin/Package423FCBGA
515POP-FCBGA
SPI4
UART(SCI)4
USB4
Video Port (Configurable)1 Dedicated Input
1 Dedicated Output
Video Resolution/Frame RateD1 or Less
720p
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSEVM3730
    AM/DM37x Evaluation Module
  • Evaluation Modules & Boards: BEAGLEXM
    BeagleBoard-xM Development Board
  • TI OMAP4430 POP SMT Design Guideline (Rev. C)
    PDF, 3.2 Мб, Версия: C, Файл опубликован: 3 ноя 2011
  • AM3715 GPMC
    PDF, 19 Кб, Файл опубликован: 3 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:href=http://processors.wiki.ti.com/index.php/Am3715_gpmcThe GPMC is a 16-bit external memory controller. The GPMC data access engine provides a flexible programming model for communicatio
  • PCB Design Req for Dist. Network for TI OMAP3630, AM37xx, and DM37xx MCUs
    PDF, 739 Кб, Файл опубликован: 15 июн 2011
    The purpose of a power distribution network (PDN) is to provide clean and reliable power to active devices in the system. The printed circuit board (PCB) is a critical component of the system-level PDN. Therefore, the PCB design is of utmost importance for high-performance low-power microprocessors. This application report provides design requirements and details a step-by-step methodology on how
  • AM3715/03 Memory Subsystem
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM3715/03_Memory_SubsystemThe Memory Subsystem in the AM3715/03 devices consists of the internal SRAM and two dedicated memory contr
  • AM37x/DM37x Schematic Checklist
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x/DM37x_Schematic_Checklist.This article provides many tips related to reset, JTAG, peripherals, etc. It should be used as
  • AM37x EVM Software Developer's Guide
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x_EVM_Software_Developer%27s_Guide.This wiki article illustrates the various software components provided with the A
  • AM/DM37x Power Estimation Spreadsheet
    PDF, 20 Кб, Файл опубликован: 7 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or tocontribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM/DM37x_Power_Estimation_SpreadsheetThis article discusses the power consumption of the Texas Instruments AM/DM37x high
  • AM/DM37x Overview
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM/DM37x_Overview.This document provides an overview of the AM37x applications processor.All trademarks are property of their respective
  • Ethernet Connectivity via GPMC
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/Ethernet_Connectivity_via_GPMCThe purpose of this article is to describe a solution for connecting Ethernet to various devices,
  • Setting up AM37x SDRC Registers
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/Setting_up_AM37x_SDRC_registersThis wiki article describes how to set the SDRC registers in the OMAP35x SDRC module depending o
  • AM37x CUS Routing Guidelines
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x_CUS_Routing_Guidelines.CUS package is designed with a new technology called Via Channelв„ў array. This technology allows for e
  • AN-1281 Bumped Die (Flip Chip) Packages (Rev. A)
    PDF, 2.2 Мб, Версия: A, Файл опубликован: 1 май 2004
    Application Note 1281 Bumped Die (Flip Chip) Packages
  • PCB Assembly Guidelines for 0.4mm Package-On-Package (PoP) Packages Part II (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 1 ноя 2013
    Once the bottom circuit board has been designed the assembly guidelines for package-on-package (PoP) versions of the OMAP35xx processor and the memory device must be considered.
    PoP packages have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of final assembly: the circuit board design the solder paste char
  • PCB Design Guidelines for 0.4mm Package-On-Package (PoP) Packages Part I (Rev. B)
    PDF, 6.7 Мб, Версия: B, Файл опубликован: 13 июн 2009
    Ball grid array (BGA) packages having 0.4mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies; the standard rules of thumb don't apply anymore. In fact the design guidelines for 0.4mm and 0.5mm differ primarily due to issues surrounding shorts or opens between balls under the processor.In addition to the de
  • 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)
    PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
  • PCB Assembly Guidelines for 0.5mm Package-on-Package Apps Processors Part II
    PDF, 1.2 Мб, Файл опубликован: 23 июн 2010
    Once the main printed circuit board (PCB) has been designed the assembly guidelines for the 0.5mm package-on-package (PoP) applications processor and companion memory device must be considered. PoP applications processors have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of PCB assembly: PoP applications process
  • PCB Design Guidelines for 0.5mm Package-On-Package Apps Processors Part I
    PDF, 2.0 Мб, Файл опубликован: 23 июн 2010
    Ball grid array (BGA) packages having 0.5mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies. PCBs with package-on-package (PoP) technology have additional assembly requirements and options that need to be considered when designing the PCB.
    Fine-pitch PCB design is a team effort and may require more than
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > DaVinci Video Processors
На английском языке: Datasheet Texas Instruments XDM3730CBP
