Оптопары и оптореле Megawin
Datasheet Texas Instruments TPS54910PWPR — Даташит
СерияTPS54910
МодельTPS54910PWPR
Входное напряжение от 3 В до 4 В, синхронный понижающий преобразователь 9 А, 28-HTSSOP от -40 до 85
3-V to 4-V Input, 9-A Output Synchronous Buck Switcher w/Integrated FETS SWIFT datasheet
PDF, 930 Кб, Версия: C, Файл опубликован: 11 фев 2005
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS54910
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)9 A
Iq(Typ)11 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Synchronous Rectification
Switching Frequency(Max)700 kHz
Switching Frequency(Min)280 kHz
ТипConverter
Vin(Max)4 В
Vin(Min)3 В
Vout(Max)2.5 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: TPS54910EVM-213
    9-A, 3-4 Vin DC/DC Converter with Ceramic Capacitors and Adjustable Output
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Dual Output Power Supply Sequencing for High Performance Processors
    PDF, 6.0 Мб, Файл опубликован: 17 июл 2002
    Dual voltage power supply architectures are becoming commonplace in high performance microprocessor and digital signal processor (DSP) systems. To save power and increase processing speeds, processor cores have smaller geometry cells and require lower supply voltages than the system bus voltages. Power management in these systems requires special attention. Yesterday's power management ICs and app
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54910 (4)
На английском языке: Datasheet Texas Instruments TPS54910PWPR
