Datasheet Texas Instruments DM3730CBPD100 — Даташит
СерияDM3730
МодельDM3730CBPD100
Цифровой медиапроцессор 515-POP-FCBGA от -40 до 90
DM3730, DM3725 Digital Media Processors datasheet
PDF, 3.3 Мб, Версия: D, Файл опубликован: 11 апр 2011
Pin515515
Package TypeCBPCBP
Industry STD TermPOP-FCBGAPOP-FCBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY168168
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаDM3730CBPD100-AS3DM3730CBPD100
Width (мм)1212
Length (мм)1212
Thickness (мм).5.5
Pitch (мм).4.4
Max Height (мм).7.7
ARM CPU1 ARM Cortex-A8
ARM MHz800,1000 Max.
ApplicationsAudio,Automotive,Communications and Telecom,Computers and Peripherals,Consumer Electronics,Energy,Industrial,Medical,Security
DRAMLPDDR
DSP1 C64x
DSP MHz660,800 Max.
I2C4
On-Chip L2 Cache256 KB (ARM Cortex-A8)
Operating SystemsAndroid,DSP/BIOS,Neutrino,ntegrity,Windows Embedded CE,Linux,VXWorks
Рабочий диапазон температурот -40 до 105,-40 до 90,0 до 90 C
Pin/Package423FCBGA, 515POP-FCBGA
SPI4
UART4 SCI
USB4
Video Port1 Dedicated Input,1 Dedicated Output Configurable
Video Resolution/Frame RateD1 or Less,720p
  • Evaluation Modules & Boards: TMDSEVM3730
    AM/DM37x Evaluation Module
  • Evaluation Modules & Boards: BEAGLEXM
    BeagleBoard-xM Development Board
  • TI OMAP4430 POP SMT Design Guideline (Rev. C)
    PDF, 3.2 Мб, Версия: C, Файл опубликован: 3 ноя 2011
  • AM3715 GPMC
    PDF, 19 Кб, Файл опубликован: 3 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:href=http://processors.wiki.ti.com/index.php/Am3715_gpmcThe GPMC is a 16-bit external memory controller. The GPMC data access engine provides a flexible programming model for communicatio
  • PCB Design Req for Dist. Network for TI OMAP3630, AM37xx, and DM37xx MCUs
    PDF, 739 Кб, Файл опубликован: 15 июн 2011
    The purpose of a power distribution network (PDN) is to provide clean and reliable power to active devices in the system. The printed circuit board (PCB) is a critical component of the system-level PDN. Therefore, the PCB design is of utmost importance for high-performance low-power microprocessors. This application report provides design requirements and details a step-by-step methodology on how
  • AM37x/DM37x Schematic Checklist
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x/DM37x_Schematic_Checklist.This article provides many tips related to reset, JTAG, peripherals, etc. It should be used as
  • AM37x EVM Software Developer's Guide
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x_EVM_Software_Developer%27s_Guide.This wiki article illustrates the various software components provided with the A
  • AM/DM37x Overview
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM/DM37x_Overview.This document provides an overview of the AM37x applications processor.All trademarks are property of their respective
  • AM/DM37x Power Estimation Spreadsheet
    PDF, 20 Кб, Файл опубликован: 7 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or tocontribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM/DM37x_Power_Estimation_SpreadsheetThis article discusses the power consumption of the Texas Instruments AM/DM37x high
  • Ethernet Connectivity via GPMC
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/Ethernet_Connectivity_via_GPMCThe purpose of this article is to describe a solution for connecting Ethernet to various devices,
  • Setting up AM37x SDRC Registers
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/Setting_up_AM37x_SDRC_registersThis wiki article describes how to set the SDRC registers in the OMAP35x SDRC module depending o
  • AM37x CUS Routing Guidelines
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM37x_CUS_Routing_Guidelines.CUS package is designed with a new technology called Via Channelв„ў array. This technology allows for e
  • AM3715/03 Memory Subsystem
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/AM3715/03_Memory_SubsystemThe Memory Subsystem in the AM3715/03 devices consists of the internal SRAM and two dedicated memory contr
  • AN-1281 Bumped Die (Flip Chip) Packages (Rev. A)
    PDF, 2.2 Мб, Версия: A, Файл опубликован: 1 май 2004
    Application Note 1281 Bumped Die (Flip Chip) Packages
  • PCB Assembly Guidelines for 0.4mm Package-On-Package (PoP) Packages Part II (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 1 ноя 2013
    Once the bottom circuit board has been designed the assembly guidelines for package-on-package (PoP) versions of the OMAP35xx processor and the memory device must be considered.
    PoP packages have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of final assembly: the circuit board design the solder paste char
  • PCB Design Guidelines for 0.4mm Package-On-Package (PoP) Packages Part I (Rev. B)
    PDF, 6.7 Мб, Версия: B, Файл опубликован: 13 июн 2009
    Ball grid array (BGA) packages having 0.4mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies; the standard rules of thumb don't apply anymore. In fact the design guidelines for 0.4mm and 0.5mm differ primarily due to issues surrounding shorts or opens between balls under the processor.In addition to the de
  • PCB Assembly Guidelines for 0.5mm Package-on-Package Apps Processors Part II
    PDF, 1.2 Мб, Файл опубликован: 23 июн 2010
    Once the main printed circuit board (PCB) has been designed the assembly guidelines for the 0.5mm package-on-package (PoP) applications processor and companion memory device must be considered. PoP applications processors have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of PCB assembly: PoP applications process
  • PCB Design Guidelines for 0.5mm Package-On-Package Apps Processors Part I
    PDF, 2.0 Мб, Файл опубликован: 23 июн 2010
    Ball grid array (BGA) packages having 0.5mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies. PCBs with package-on-package (PoP) technology have additional assembly requirements and options that need to be considered when designing the PCB.
    Fine-pitch PCB design is a team effort and may require more than
  • 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)
    PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments DM3730CBPD100
