Datasheet Texas Instruments UC3834DW — Даташит
СерияUC3834
МодельUC3834DW
Высокоэффективный линейный регулятор 16-SOIC от 0 до 70
High Efficiency Linear Regulator datasheet
PDF, 1.1 Мб, Файл опубликован: 5 сен 1999
Pin16
Package TypeDW
Package QTY40
МаркировкаUC3834DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Fixed Output Options1.5 В
Iq(Typ)5.5 мА
Output OptionsFixed Output
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Thermal Resistance ОёJA65 В°C/W
Vin(Max)36 В
Vin(Min)5 В
Vout(Max)35 В
Vout(Min)2 В
  • Versatile UC1834 Optimizes Linear Regulator Efficiency
    PDF, 463 Кб, Файл опубликован: 5 сен 1999
    Linear voltage regulators have long been an important resource to power supply designers. Three-terminal fixed-voltage linear regulators find extensive use as spot regulators and as post-regulation stages fed by switched-mode supplies. However while inexpensive and simple to use these devices have several performance limitations. They are inefficient power converters they lack versatility an
Серия: UC3834 (2)
  • Semiconductors > Power Management > Linear Regulator (LDO) > LDO Controller (External FET)
На английском языке: Datasheet Texas Instruments UC3834DW
