Datasheet Texas Instruments UC3525AQG3 — Даташит
СерияUC3525A
МодельUC3525AQG3
Регулирующие широтно-импульсные модуляторы 20-PLCC от 0 до 70
UCx52xA Regulating Pulse Width Modulators datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 27 июл 2017
IC REG CTRLR MULT TOP 20PLCC. Buck, Boost, Flyback, Forward Converter, Full-Bridge, Half-Bridge, Push-Pull Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC...
UC3525AQG3
128 ₽
UC3525AQG3
133 ₽
UC3525AQG3
330 ₽
Hi-Tech Circuit Group
UC3525AQG3
Pin20
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Package QTY46
МаркировкаUC3525AQ
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.06
Max Height (мм)4.57
Control MethodVoltage
Duty Cycle(Max)49 %
Frequency(Max)500 kHz
Frequency(Min)0.1 kHz
Gate Drive(Typ)0.4 A
Package GroupPDIP,SOIC
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7.0/6.5 В
Vin(Max)35 В
Vin(Min)8 В
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3525AQG3
