Datasheet Texas Instruments UC2907DWTRG4 — Даташит
СерияUC2907
МодельUC2907DWTRG4
Контроллер распределения нагрузки 16-SOIC от -40 до 85
Load Share Controller datasheet
PDF, 351 Кб, Версия: C, Файл опубликован: 9 янв 2002
Pin16
Package TypeDW
Package QTY2000
МаркировкаUC2907DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Operating Supply Current6 мА
Operating Supply(Max)35 В
Operating Supply(Min)4.5 В
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Share BusSingle-Ended
Special FeaturesOn-Board Reference
Startup Current3000 uA
  • Evaluation Modules & Boards: UCC39002EVM
    UCC39002 Evaluation Module
  • U-129 UC3907 Load Share IC Simplifies Parallel Power Supply Design
    PDF, 251 Кб, Файл опубликован: 5 сен 1999
    The UC3907 family of Load Share Controller ICs provides all the necessary features to allow multiple independent power modules to be paralleled, so each module supplies only its proportionate share to total load current. Many power supply manufacturers have found it economically feasible to make standard modular power supplies which are easily paralleled for higher current applications. If speci
Серия: UC2907 (7)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Load Share
На английском языке: Datasheet Texas Instruments UC2907DWTRG4
