Datasheet Texas Instruments TPS61166DSKR — Даташит
СерияTPS61166
МодельTPS61166DSKR
Драйвер белого светодиода со встроенным силовым диодом и режимом быстрого пакетного регулирования яркости 10-SON от -40 до 85
White LED Driver With Integrated Power Diode and Fast Burst Mode Dimming datasheet
PDF, 1.1 Мб, Файл опубликован: 16 сен 2009
IC LED DRIVER RGLTR DIM 10SON. LED Driver IC 1 Output DC DC Regulator Step-Up (Boost) PWM Dimming 1.1A (Switch) 10-SON...
TPS61166DSKR
29 ₽
TPS61166DSKR
69 ₽
ТаймЧипс
TPS61166DSKR
727GS
TPS61166DSKR
Pin10
Package TypeDSK
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаOAO
Width (мм)2.5
Length (мм)2.5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Количество каналов1
Duty Cycle(Max)93 %
LED5
LED Current Per Channel400 мА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Peak Efficiency85 %
Shutdown Current(Typ)1 uA
Special FeaturesEasyScale 1-Wire Interface,OVP
Switching Frequency(Max)1400 kHz
TopologyBoost
ТипInductive
Vin(Max)10 В
Vin(Min)2.5 В
Vout(Max)17 В
Vout(Min)2.5 В
  • How to Use Analog Dimming With TPS6116x
    PDF, 162 Кб, Файл опубликован: 5 авг 2011
    The TPS6116x family of devices are simple, white LED drivers that can drive up to 10 LEDs in series. The CTRL pin on these devices is the input for the integrated analog dimming circuitry but can only be used for PWM signals switching higher than 5 kHz. This application report shows a simple, external circuit that can be used to perform analog dimming from PWM signals that are below 5 kHz as well
Серия: TPS61166 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61166DSKR
