Datasheet Texas Instruments LM25115SDX/NOPB — Даташит
СерияLM25115
МодельLM25115SDX/NOPB
42 В, вторичный боковой пост-регулятор/контроллер синхронного понижения 16-WSON от -40 до 125
LM25115 Secondary Side Post Regulator Controller datasheet
PDF, 978 Кб, Версия: A, Файл опубликован: 1 апр 2013
Pin16
Package TypeNHQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY4500
МаркировкаL25115
Width (мм)5
Length (мм)5
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Control MethodCurrent,Voltage
Duty Cycle(Max)85 %
Frequency(Max)1000 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)2.5 A
Package GroupWSON
Special FeaturesFrequency Synchronization,Soft Start,Synchronization Pin,Thermal Shutdown
TopologySynchronous secondary-side post-regulator
UVLO Thresholds On/Off4.15/4.0 В
Vin(Max)42 В
Vin(Min)4.5 В
  • Minimizing FET Losses For a High Input Rail Buck Converter (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Engineers often face the challenge of choosing the input voltage rail that works best for the DC-DCconverter at the point-of-load (POL). High voltage rails, above 12 V, usually demand intermediateregulation stages that reduce overall efficiency and add to cost. However, the new generation of regulatorand controller ICs afford POL regulation from these high input rails directly. Typically the
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM25115 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments LM25115SDX/NOPB
