Datasheet Texas Instruments SN65HVD37DR — Даташит
СерияSN65HVD37
МодельSN65HVD37DR
Маломощный полнодуплексный драйвер/приемник RS-485, 3,3 В, 14-SOIC от -40 до 85
Low-Power 3.3V-Supply Full-Duplex RS-485 Driver/Receiver datasheet
PDF, 386 Кб, Версия: A, Файл опубликован: 29 ноя 2011
39 предложений от 17 поставщиков
SN65HVD37DR
от 40 ₽
Зенер
Россия и страны ТС
SN65HVD37DR
от 292 ₽
SN65HVD37DR
от 304 ₽
SN65HVD37DR
369 ₽
Pin14
Package TypeD
Package QTY2500
МаркировкаHVD37
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexFull
Fail SafeIdle,Open,Short
Fault Protection-13 to 13 В
HBM ESD15 kV
ICC(Max)0.8 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Signaling Rate(Max)20 Mbps
Supply Voltage(s)(Nom)3.3 В
  • Evaluation Modules & Boards: SN65HVD22EVM
    SN65HVD22EVM Evaluation Module
  • Evaluation Modules & Boards: RS485-FL-DPLX-EVM
    RS485-FL-DPLX-EVM: RS-485 Full-Duplex Evaluation Module
  • Comparison of Differential-Mode Noise Immunity of RS-485 Recvrs W/3.3-V Supply
    PDF, 1.0 Мб, Файл опубликован: 29 ноя 2011
    RS-485 is a widely used standard for industrial communication due to its simplicity and suitability for use in high-noise environments on long cables. Inherent in the standard are balanced signal drivers and receivers, which use differential signaling to reject common-mode noise. Receiver hysteresis is commonly used to ensure glitch-free reception even when differential noise is present. This appl
Серия: SN65HVD37 (2)
На английском языке: Datasheet Texas Instruments SN65HVD37DR
