Datasheet Texas Instruments PCA9544AZQNR — Даташит
| Серия | PCA9544A |
| Модель | PCA9544AZQNR |
4-канальный мультиплексор I2C и SMBus с логикой прерываний, 20 BGA MICROSTAR JUNIOR от -40 до 85
PCA9544A Low Voltage 4-Channel IВІC and SMBus Multiplexer With Interrupt Logic datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 12 июн 2014
17 предложений от 16 поставщиков IC INTERFACE SPECIALIZED 20BGA. Translating Switch Interface 20-BGA MICROSTAR JUNIOR (4x3). Interface - Specialized | |||
| PCA9544AZQNR Texas Instruments | 122 ₽ | ||
| PCA9544AZQNR Texas Instruments | от 182 ₽ | ||
| PCA9544AZQNR Texas Instruments | 202 ₽ | ||
| PCA9544AZQNR Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | ZQN |
| Industry STD Term | BGA MICROSTAR JUNIOR |
| JEDEC Code | R-PBGA-N |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | PD544A |
| Width (мм) | 3 |
| Length (мм) | 4 |
| Thickness (мм) | .75 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Channel Width | 4 |
| I2C Address | 1110 xxx |
| Package Group | BGA MICROSTAR JUNIOR |
| Simultaneously Active Channels | 1 |
| Special Features | Interrupt Output,5V Tolerant I/O |
| VCC(Max) | 5.5 В |
| VCC(Min) | 2.3 В |
| fSCLK(Max) | 0.4 МГц |
| tpd max | 1 нс |
- Troubleshooting I2C Bus ProtocolPDF, 184 Кб, Файл опубликован: 19 окт 2009
When using the I2Cв„ў bus protocol, the designer must ensure that the hardware complies with the I2C standard. This application report describes the I2C protocol and provides guidelines on debugging a missing acknowledgment, selecting the pullup resistors, or meeting the maximum capacitance load of an I2C bus. A conflict occurs if devices sharing the I2C bus have the same slave address. This - Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCA9544A (11)
- Semiconductors > Interface > I2C > I2C Switches and Multiplexers
