Datasheet Texas Instruments 5962-9584401VRA — Даташит
| Серия | SN54LVTH244A-SP |
| Модель | 5962-9584401VRA |
Восьмеричные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 20-CDIP от -55 до 125
SN54LVTH244A, SN74LVTH244A datasheet
PDF, 1.5 Мб, Версия: J, Файл опубликован: 8 окт 2003
Купить 5962-9584401VRA на РадиоЛоцман.Цены — от 13 521 до 17 197 ₽Микросхема Логический чип, Buffer/Line Driver 8CH Non-Inverting 3-ST BiCMOS 20Pin CDIP Tube | |||
| 5962-9584401VRA Texas Instruments | 13 521 ₽ | ||
| 5962-9584401VRA Texas Instruments | 17 197 ₽ | ||
| 5962-9584401VRA Texas Instruments | по запросу | ||
| Pin | 20 | 20 | 20 |
| Package Type | J | J | J |
| Industry STD Term | CDIP | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 | 1 |
| Carrier | TUBE | TUBE | TUBE |
| Маркировка | A | SNV54LVTH244AJ | 5962-9584401VR |
| Width (мм) | 6.92 | 6.92 | 6.92 |
| Length (мм) | 24.2 | 24.2 | 24.2 |
| Thickness (мм) | 4.57 | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 | 5.08 |
| Mechanical Data | Скачать | Скачать | Скачать |
| Bits | 8 |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Тип выхода | LVTTL |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Space |
| Schmitt Trigger | No |
| Technology Family | LVT |
| VCC(Max) | 3.6 В |
| VCC(Min) | 2.7 В |
| Voltage(Nom) | 3.3 В |
| RoHS | See ti.com |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed. - Understanding Advanced Bus-Interface Products Design GuidePDF, 253 Кб, Файл опубликован: 1 май 1996
- TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
The Input/Output Buffer Information Specification (IBIS) also known as ANSI/EIA-656 has become widely accepted among electronic design automation (EDA) vendors semiconductor vendors and system designers as the format for digital electrical interface data. Because IBIS models do not reveal proprietary internal processes or architectural information semiconductor vendors? support for IBIS con - Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Many telecom and networking applications require that cards be inserted and extracted from a live backplane without interrupting data or damaging components. To achieve this interface terminals of the card must be electrically isolated from the bus system during insertion or extraction from the backplane. To facilitate this Texas Instruments provides bus-interface and logic devices with features - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
Серия: SN54LVTH244A-SP (3)
- 5962-9584401V2A 5962-9584401VRA 5962-9584401VSA
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
59629584401VRA, 5962 9584401VRA
