Datasheet Texas Instruments BQ2007S — Даташит
СерияBQ2007
МодельBQ2007S
NiCd/NiMH ИС импульсного управления зарядом с усовершенствованным драйвером светодиодного и ЖК-дисплея 24-SOIC от 0 до 70
Pin24
Package TypeDW
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • U-509 Using the bq2007 Enhanced Features for Fast Charge
    PDF, 178 Кб, Файл опубликован: 5 сен 1999
    The bq2007 is a highly integrated, fast-charge, monolithic CMOS IC that provides intelligent battery charging and charge-status monitoring for stand-alone charging systems. This application note describes the correct setup of the bq2007 features and gives examples for NICd or NiMH switch-mode and gated source fast-charger applications.
  • U-508 Using the bq2007 Display Mode Options
    PDF, 69 Кб, Файл опубликован: 5 сен 1999
    The bq2007 is a highly integrated, fast-charge, monolithic CMOS IC that provides intelligent battery charging and charge-status monitoring for stand-alone charging systems. This application note describes the wide variety of charge-status monitor display formats available on the bq2007.
Серия: BQ2007 (3)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ2007S
