Datasheet Texas Instruments LM741CN/NOPB — Даташит
СерияLM741
МодельLM741CN/NOPB
Операционный усилитель 8-PDIP от 0 до 70
LM741 Operational Amplifier datasheet
PDF, 688 Кб, Версия: D, Файл опубликован: 30 окт 2015
Pin88
Package TypePP
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
Package QTY4040
CarrierTUBETUBE
МаркировкаLM741CN
Width (мм)6.356.35
Length (мм)9.819.81
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)70 дБ
CMRR(Typ)90 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)210000 pA
Iq per channel(Max)2.8 мА
Iq per channel(Typ)1.7 мА
Количество каналов1
Offset Drift(Typ)15 uV/C
Output Current(Typ)25 мА
Package GroupPDIP
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Max)44 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)30 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • AN-71 Micropower Circuits Using the LM4250 Programmable Op Amp (Rev. B)
    PDF, 536 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application report describes the circuit operation of the Texas Instruments LM4250, various methodsof biasing the device, frequency response considerations, and some circuit applications exercising theunique characteristics of the LM4250.
  • Predicting Op Amp Slew Rate Limited Response
    PDF, 139 Кб, Файл опубликован: 7 окт 2002
  • AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)
    PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
    Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • Low Drift Amplifiers
    PDF, 71 Кб, Файл опубликован: 2 окт 2002
  • LM143 Monolithic High Voltage Operational Amplifier Applications
    PDF, 479 Кб, Файл опубликован: 2 май 2004
    Application Note 127 LM143 Monolithic High Voltage Operational Amplifier Applications
  • AN-480 A 40 MHz Programmable Video Op Amp
    PDF, 218 Кб, Файл опубликован: 11 май 2004
  • Get Fast Stable Response From Improved Unity-Gain Followers
    PDF, 107 Кб, Файл опубликован: 2 окт 2002
  • AN-711 LM78S40 Switching Voltage Regulator Applications (Rev. B)
    PDF, 740 Кб, Версия: B, Файл опубликован: 7 май 2013
    This application note describes a new integrated subsystem that contains the control circuitry, as well asthe switching elements, required for constructing switching regulator systems.
  • LM118 Op Amp Slews 70 V/sec
    PDF, 118 Кб, Файл опубликован: 1 окт 2002
    LM118 Op Amp Slews 70 V/ГѓВґsec
Серия: LM741 (3)
На английском языке: Datasheet Texas Instruments LM741CN/NOPB
