Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI UC3707N — Даташит
СерияUC3707
МодельUC3707N
Datasheet Texas Instruments UC3707N
Дополнительные высокоскоростные драйверы питания 16-PDIP от 0 до 70
Dual Channel Power Driver datasheet
PDF, 973 Кб, Версия: B, Файл опубликован: 16 сен 2008
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC3707 (4)
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UC3707N
Политика конфиденциальности
