Datasheet Texas Instruments LM324MX — Даташит
СерияLM324-N
МодельLM324MX
Счетверенный операционный усилитель малой мощности 14-SOIC от 0 до 70
LMx24-N, LM2902-N Low-Power, Quad-Operational Amplifiers datasheet
PDF, 1.9 Мб, Версия: D, Файл опубликован: 26 янв 2015
33 предложений от 27 поставщиков
LM324MX
Fairchild
16 ₽
Элитан
LM324MX
20 ₽
Microfind
LM324MX/NOPB
24 ₽
LM324MX/NOPB
97 ₽
Pin14
Package TypeD
Package QTY2500
МаркировкаLM324M
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementLM324MX/NOPB
Replacement CodeS
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)65 дБ
CMRR(Typ)85 дБ
GBW(Typ)1 МГц
IIB(Max)100000 pA
Iq per channel(Max)0.3 мА
Iq per channel(Typ)0.18 мА
Количество каналов4
Offset Drift(Typ)7 uV/C
Output Current(Typ)20 мА
Rail-to-RailIn to V-
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)40 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)7 мВ
RoHSSee ti.com
  • Mounting of Surface Mount Components (Rev. B)
    PDF, 5.8 Мб, Версия: B, Файл опубликован: 23 апр 2013
    Over the past few years, electronic products, and especially those which fall within the category ofConsumer Electronics, have been significantly reduced in physical size and weight. This documentprovides information about the techniques used to mount CSP size components.
  • AN-666 DTMF Generation with 3.58 MHz Crystal
    PDF, 798 Кб, Файл опубликован: 14 май 2004
  • AN-C V/F Converter ICs Handle Frequency-to-Voltage Needs (Rev. B)
    PDF, 371 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Simplify your frequency-to-voltage (F/V) converter designs with versatile V/F ICs. Starting with a basicconverter circuit you can modify it to meet almost any application requirement. You can spare yourselfsome hard labor when designing F/V converters by using a voltage-to-frequency (V/F) IC in your designs.These ICs form the basis of a series of accurate yet economical F/V converters sui
  • Get More Power Out of Dual or Quad Op-Amps
    PDF, 91 Кб, Файл опубликован: 2 окт 2002
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
На английском языке: Datasheet Texas Instruments LM324MX
