Datasheet Texas Instruments S5LS20206ASPGEQQ1R — Даташит
| Серия | TMS570LS20206 |
| Модель | S5LS20206ASPGEQQ1R |
Флэш-микроконтроллер ARM Cortex-R4F 144-LQFP от -40 до 125
TMS570LS20216/20206/10216/10206/10116/10106 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 1.6 Мб, Версия: F, Файл опубликован: 7 сен 2011
Купить S5LS20206ASPGEQQ1R на РадиоЛоцман.Цены — от 1 746 до 6 994 ₽11 предложений от 11 поставщиков IC MCU 32BIT 2MB FLASH 144LQFP. ARM® Cortex®-R4F Automotive, AEC-Q100, HerculesTM TMS570 ARM® Cortex®-R Microcontroller IC 16/32-Bit 140MHz 2MB (2M... | |||
| S5LS20206ASPGEQQ1R Texas Instruments | 2 647 ₽ | ||
| S5LS20206ASPGEQQ1R Texas Instruments | 6 994 ₽ | ||
| S5LS20206ASPGEQQ1R Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 144 | 144 |
| Package Type | PGE | PGE |
| Industry STD Term | LQFP | LQFP |
| JEDEC Code | S-PQFP-G | S-PQFP-G |
| Package QTY | 500 | 500 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | 20206ASPGEQQ1 | TMS570LS |
| Width (мм) | 20 | 20 |
| Length (мм) | 20 | 20 |
| Thickness (мм) | 1.4 | 1.4 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1.6 | 1.6 |
- Use of Flash Test Pins on TMSx70 F035 Devices (Rev. A)PDF, 30 Кб, Версия: A, Файл опубликован: 10 мар 2010
Texas Instruments TMSx70 microcontrollers built using TI's F035 Flash process have one or two test pins used for advanced testing of the Flash memory. This application report discusses how to utilize these pins when designing circuit boards for one of these processors. - Interfacing the Embedded 12-Bit ADC in a TMS570LS20x/10x Series Device (Rev. A)PDF, 769 Кб, Версия: A, Файл опубликован: 6 ноя 2011
The Texas Instruments Herculesв„ў ARMВ® Safety Microcontrollers TMS570LS20x/10x series products have two 12-bit analog-to-digital converters (ADC). This document provides the device configuration and layout recommendations to achieve the best performance of the embedded ADC, including: layout requirements on power and ground, decoupling/bypass capacitor requirements on voltage reference pins an - Recommended Initializations for TMS570LS20x/10x MicrocontrollersPDF, 62 Кб, Файл опубликован: 4 мар 2010
This application report covers the recommended initialization procedure for TMS570LS20x/10x Microcontrollers. It includes core registers, memories, ECC, FPU, clocks, and peripherals. - Programming TMS570LS20x/10x Flash Using Flash API (Rev. A)PDF, 100 Кб, Версия: A, Файл опубликован: 27 май 2010
The Texas Instrument's TMS570Px products have Flash memory that can store data or machine code for execution. This document provides a high-level overview of the TMS570Px Flash architecture and Flash API, focusing on the erasing and programming of TMS570Px Flash using Flash API. - Compatibility Considerations: TMS570LS20x/10x to TMS570LS31x/21x (Rev. A)PDF, 138 Кб, Версия: A, Файл опубликован: 20 окт 2011
This application report provides a summary of the main changes required for porting an application written on the Herculesв„ў TMS570LS20x/10x series of microcontrollers over to the Hercules TMS570LS31x/21x series of microcontrollers. A brief description of the process technology differences is also included. - NHET Getting Started (Rev. B)PDF, 1.7 Мб, Версия: B, Файл опубликован: 30 авг 2010
This application report describes the basic steps necessary to generate a simple pulse width modulation (PWM) with the next generation high-end timer (NHET) module. It reviews the calculations necessary to achieve a PWM with a certain frequency and duty cycle, setting up the NHET registers and writing the NHET program. Finally, it shows code excerpts of the setup to run the simple example code.ECC Handling in TMSx70-Based MicrocontrollersPDF, 126 Кб, Файл опубликован: 23 фев 2011
This application report describes the Flash and RAM ECC handling methods for TMSx70-based microcontrollers in general.To use the Flash/RAM ECC, the single error correction and double error detection (SECDED) module in the TMSx70 has to be configured accordingly. This application report covers typical software configurations of the SECDED modules and briefly explains some essential basics.Verification of Data Integrity Using CRCPDF, 83 Кб, Файл опубликован: 17 фев 2012
The purpose of this application report is to provide help setting up the cyclic redundancy check (CRC) controller of the Herculesв„ў TMS570 and RM4 microcontrollers. The Hercules microcontrollers from Texas Instruments are 32-bit RISC microcontrollers based on the ARMВ® Cortexв„ў-R4 core with an advanced architecture and a rich peripheral set that supports on-chip diagnostics to aExecution Time Measurement for Hercules ARM Safety MCUs (Rev. A)PDF, 86 Кб, Версия: A, Файл опубликован: 4 ноя 2011
This application report describes methods for measuring code execution time of TMS470 and TMS570 microcontrollers. Besides the typical pin toggle approach, where the duration between two pin toggles is measured, e.g., with an oscilloscope, Hercules MCUs support cycle count methods to measure the code execution time in terms of clock cycles.The real-time-interrupt (RTI) module hardware countLeveraging the High-End Timer Transfer Unit on Hercules ARM Safety MCUs (Rev. A)PDF, 64 Кб, Версия: A, Файл опубликован: 6 сен 2011
This application report shows how the high-end timer transfer unit (HTU), a local DMA on the TMS570 and RM4x devices that is dedicated to the extremely versatile programmable timer co-processor (NHET), can be used to offload tasks from the main CPU by doing transfers between the main memory and the NHET. It shows how to set up the HTU, covers specific details that need to be taken into account wheBasic PBIST Configuration and Influence on Current Consumption (Rev. C)PDF, 368 Кб, Версия: C, Файл опубликован: 12 апр 2012
The purpose of this application report is to provide help for configuring the PBIST module of TMS570LS series microcontrollers. It also explains the configurations, the different algorithm test durations and the influence on current consumptions.Interfacing TPS65381 With Hercules Microcontrollers (Rev. A)PDF, 155 Кб, Версия: A, Файл опубликован: 14 фев 2014
The application report provides help to design a safety system with both the Hercules safety microcontrollers and the TPS65381 power supply. The document explains the hardware considerations and the software flowchart.Configuring the Hercules ARM Safety MCU SCI/LIN Module for UART Communication (Rev. A)PDF, 548 Кб, Версия: A, Файл опубликован: 6 сен 2011
The purpose of this application report is to provide help for configuring the SCI/LIN module of Hercules microcontrollers for universal asynchronous receiver-transmitter (UART) communication. The document explains the SCI/LIN module configuration done in the UART driver that is used by Texas Instruments (TIв„ў) in a safety demo of the Hercules product family. The Hercules family of microcontroGenerating Operating System Tick Using RTI on a Hercules ARM Safety MCUPDF, 659 Кб, Файл опубликован: 13 июл 2010
The purpose of this application report is to provide help for setting up the RTI Module of Hercules Safety Microcontrollers. The Hercules family of microcontrollers from Texas Instruments is a family of 32-bit RISC microcontrollers with an advanced safety architecture and a rich peripheral set.Usage of MPU Subregions on TI Hercules ARM Safety MCUsPDF, 79 Кб, Файл опубликован: 10 мар 2010
A Memory Protection Unit (MPU) is a module used to modify the memory types and attributes as defined in a processor’s memory ordering model. The MPU is specific to each core in the system and can only modify the memory ordering model of the CPU to which it is attached. If Texas Instruments TMSx70 platform of devices include a CortexR4 or a CortexM3 core, then as part of the core architecture, a MPADC Source Impedance for Hercules ARM Safety MCUs (Rev. B)PDF, 376 Кб, Версия: B, Файл опубликован: 6 сен 2011
Unbuffered multiplexed ratiometric analog-to-digital converters (ADC) have strict requirements on driving source impedance that are not always obvious. This application report addresses the trade-offs between source impedance and sample rate. It includes both 10-bit and 12-bit examples using the TMS470 processors and the Hercules ARM Safety MCUs (TMS470M, TMS570 and RM4x families) in the GS30, GS4Configuring a CAN Node on Hercules ARM Safety MCUsPDF, 1.4 Мб, Файл опубликован: 6 сен 2011Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUsPDF, 61 Кб, Файл опубликован: 17 ноя 2011
The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HETPDF, 476 Кб, Файл опубликован: 1 май 2015
This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system sSine Wave Generation Using PWM With Hercules N2HET and HTUPDF, 371 Кб, Файл опубликован: 12 май 2015
This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as weМодельный ряд
Серия: TMS570LS20206 (3)- S5LS20206ASPGEQQ1 S5LS20206ASPGEQQ1R S5LS20206ASZWTQQ1
- Semiconductors > Microcontrollers (MCU) > Performance MCUs > Safety > Hercules TMS570
На английском языке: Datasheet Texas Instruments S5LS20206ASPGEQQ1R
