Datasheet Texas Instruments LM3697YFQR — Даташит
Серия | LM3697 |
Модель | LM3697YFQR |
3-струнный драйвер подсветки с 11-битным экспоненциальным регулированием яркости 12-DSBGA от -40 до 125
LM3697 High-Efficiency Three-String White LED Driver datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 23 окт 2015
Pin | 12 |
Package Type | YFQ |
Industry STD Term | DSBGA |
JEDEC Code | R-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | D8 |
Thickness (мм) | .42 |
Pitch (мм) | .4 |
Max Height (мм) | .675 |
Mechanical Data | Скачать |
Количество каналов | 3 |
Duty Cycle(Max) | 94 % |
LED | 30 |
LED Current Per Channel | 30 мА |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Peak Efficiency | 91 % |
Rating | Catalog |
Shutdown Current(Typ) | 1 uA |
Special Features | I2C Control,OVP,PWM Control |
Switching Frequency(Max) | 1100 kHz |
Topology | Boost |
Тип | Inductive |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
Vout(Max) | 41.1 В |
- Evaluation Modules & Boards: LM3697EVM
Evaluation Module for LM3697 Three String White LED Driver for Smartphone Handsets
- Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM3697 (1)
- LM3697YFQR
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
