Datasheet Texas Instruments PCA9515APW — Даташит
СерияPCA9515A
МодельPCA9515APW
Двойная двунаправленная шина I2C и повторитель SMBus 8-TSSOP от -40 до 85
PCA9515A Dual Bidirectional I2C Bus and SMBus Repeater datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 12 июн 2014
Package TypePW
Industry STD TermTSSOP
Package QTY150
МаркировкаPD515A
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Channel Width2
Master Side I2C Bus Capacitance Supported400 пФ
Max Frequency400 kHz
Количество выходов2
Package GroupTSSOP
Slave Side I2C Bus Capacitance Supported400 пФ
Special FeaturesOpen-Drain I/O Type
VCC(Max)3.6 В
VCC(Min)2.3 В
fSCLK(Max)0.4 МГц
  • Troubleshooting I2C Bus Protocol
    PDF, 184 Кб, Файл опубликован: 19 окт 2009
    When using the I2Cв„ў bus protocol, the designer must ensure that the hardware complies with the I2C standard. This application report describes the I2C protocol and provides guidelines on debugging a missing acknowledgment, selecting the pullup resistors, or meeting the maximum capacitance load of an I2C bus. A conflict occurs if devices sharing the I2C bus have the same slave address. This
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
На английском языке: Datasheet Texas Instruments PCA9515APW
