Datasheet Texas Instruments LM25576Q0MHX/NOPB — Даташит
СерияLM25576-Q1
МодельLM25576Q0MHX/NOPB
SIMPLE SWITCHERВ® 42V, 3A Step-Down Switching Regulator 20-HTSSOP
LM25576/LM25576Q SIMPLE SWITCHERВ® 42V, 3A Step-Down Switching Regulator (Rev. G)
PDF, 1.0 Мб, Версия: G, Файл опубликован: 3 апр 2013
Статус продуктаСкоро будет снят с производства (Производитель объявил о скором прекращении производства прибора)
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаQ0MHLM25576
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Approx. Price (US$)2.30 | 1ku
Control ModeCurrent Mode
Duty Cycle(Max)(%)95
Iout(Max)(A)3
Iq(Typ)(mA)1
Operating Temperature Range(C)-40 to 125
Package GroupHTSSOP
RatingAutomotive
Regulated Outputs(#)1
Special FeaturesFrequency Synchronization
Switching Frequency(Max)(kHz)1000
Switching Frequency(Min)(kHz)50
ТипConverter
Vin(Max)(V)42
Vin(Min)(V)6
Vout(Max)(V)40
Vout(Min)(V)1.23
  • Evaluation Modules & Boards: LM25576EVAL
    Evaluation Board for LM26676, 42V, 3A Step-Down Switching Regulator
  • Quick Start Guide for a 3 Amp Buck Regulator Using the LM5576 and LM25576 (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides an easy to use process to design a 3 Amp buck regulator using the LM5576and LM25576 switching regulators.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Overcoming Challenges in Designing Step-Dwn Reg Apps w/40V Input Voltage
    PDF, 538 Кб, Файл опубликован: 30 мар 2007
На английском языке: Datasheet Texas Instruments LM25576Q0MHX/NOPB
