Datasheet Texas Instruments LM20154MH/NOPB — Даташит
СерияLM20154
МодельLM20154MH/NOPB
Синхронный понижающий стабилизатор 4А, 1 МГц с SYNCOUT 16-HTSSOP от -40 до 125
LM20154/LM20154Q 4A, 1MHz Synchronous Buck Regulator with SYNCOUT datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 27 мар 2013
24 предложений от 15 поставщиков
IC REG BUCK ADJ 4A 16HTSSOP. Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 4A 16-PowerTSSOP (0.173', 4.40mm Width). PMIC...
LM20154MH/NOPB
от 61 ₽
LM20154MH/NOPB
214 ₽
Xinhuo Future
LM20154MH/NOPB
383 ₽
LM20154MH/NOPB
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаMH20154
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)85 %
Iout(Max)4 A
Iq(Typ)3.5 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Phase Interleaving,Power Good,Synchronous Rectification,Tracking
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)1000 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.95 В
Vout(Max)5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM20154EVAL
    4A, 1Mhz PowerWiseВ® - Synchronous Buck Regulator with SYNCOUT Evaluation Module
  • AN-2077 LM20k POL Module (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
    The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta
  • Powering FPGAs Using LM201xx PowerWise Synchronous Buck Regulators (Rev. A)
    PDF, 45 Кб, Версия: A, Файл опубликован: 3 май 2013
    The LM201xx family offers a full range of features and options enabling a FPGA designer to fullycustomize their power solution to meet the system application needs.
Серия: LM20154 (3)
На английском языке: Datasheet Texas Instruments LM20154MH/NOPB
