Datasheet Texas Instruments LMH7322SQX/NOPB — Даташит
| Серия | LMH7322 |
| Модель | LMH7322SQX/NOPB |
Двойной высокоскоростной компаратор 700 пс с выходами RSPECL 24-WQFN от -40 до 125
LMH7322 Dual 700 ps High Speed Comparator with RSPECL Outputs datasheet
PDF, 948 Кб, Версия: I, Файл опубликован: 18 мар 2013
Купить LMH7322SQX/NOPB на РадиоЛоцман.Цены — от 248 до 362 ₽12 предложений от 12 поставщиков IC COMP DUAL 700PS RSPECL 24WQFN. Comparator General Purpose Differential, LVDS, RSPECL 24-WQFN (4x4). Linear - Comparators | |||
| LMH7322SQX/NOPB Texas Instruments | 362 ₽ | ||
| LMH7322SQX/NOPB Texas Instruments | по запросу | ||
| Pin | 24 |
| Package Type | RTW |
| Industry STD Term | WQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 4500 |
| Carrier | LARGE T&R |
| Маркировка | L7322SQ |
| Width (мм) | 4 |
| Length (мм) | 4 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Input Bias Current (+/-)(Max) | 5000 нА |
| Iq per channel(Max) | 15 мА |
| Количество каналов | 2 |
| Тип выхода | RSPECL |
| Package Group | WQFN |
| Package Size: mm2:W x L | 24WQFN: 16 mm2: 4 x 4(WQFN) PKG |
| Propagation Delay Time | 0.0007 uS |
| Rail-to-Rail | No |
| Rating | Catalog |
| Special Features | Strobe |
| VICR(Max) | 10.5 В |
| VICR(Min) | 0.2 В |
| Vos (Offset Voltage @ 25C)(Max) | 8 мВ |
| Vs(Max) | 12 В |
| Vs(Min) | 2.7 В |
- Evaluation Modules & Boards: LMH7322EVAL
LMH7322 Dual 700ps High Speed Comparator with RSPECL Outputs Evaluation Board
- Interface Circuits for TIA/EIA-644 (LVDS) (Rev. B)PDF, 69 Кб, Версия: B, Файл опубликован: 16 сен 2002
This design note provides information concerning the designing of TIA/EIA-644 interface circuits. The TIA/EIA-644 standard is discussed including electrical characteristics, interconnections, line termination, and noise immunity. Finally, eye patterns are used to measure the effects of signal distortion, noise, signal attenuation, and the resultant intersymbol interference (ISI) in a data transmis - Interfacing Different Logic with LVDS ReceiversPDF, 197 Кб, Файл опубликован: 14 май 2001
This application report provides explanations and design considerations for interfacing RS-422, differential current mode logic (CML), differneital emitter coupled logic (ECL), and single-ended drivers with low-voltage differential signal (LVDS) receivers.
Серия: LMH7322 (3)
- LMH7322SQ/NOPB LMH7322SQE/NOPB LMH7322SQX/NOPB
- Semiconductors > Amplifiers > Comparators
