Datasheet ТI TAS5411QPWPRQ1 — Даташит
СерияTAS5411-Q1
МодельTAS5411QPWPRQ1
Datasheet Texas Instruments TAS5411QPWPRQ1
8-W Analog Input Mono Automotive Class-D Audio Amplifier With Load Dump, I2C Diagnostics​​ 16-HTSSOP -40 to 125
TAS5411-Q1 8-W Mono Automotive Class-D Audio Amplifier With Load Dump and I2C Diagnostics datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 9 дек 2015
  • Short-to-Battery Protection Strategies for Class-D Amplifiers
    PDF, 3.2 Мб, Файл опубликован: 11 ноя 2016
    This document introduces the potential faults that can occur in class-D amplifier solutions, and describes how most faults are intrinsically protected for and how to extend coverage to protect against all short-circuit faults. Of particular focus is the case when an output is shorted to a battery voltage higher than the device supply voltage. This fault allows the parasitic body diode found in the
  • Class-D LC Filter Design (Rev. B)
    PDF, 488 Кб, Версия: B, Файл опубликован: 20 фев 2015
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5411-Q1 (1)
  • TAS5411QPWPRQ1
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TAS5411QPWPRQ1
Политика конфиденциальности
