Datasheet Texas Instruments THS5671AIPWRG4 — Даташит
СерияTHS5671A
МодельTHS5671AIPWRG4
14-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 28-TSSOP от -40 до 85
14-Bit, 125 MSPS, CommsDAC(TM) Digital-to-Analog Converter datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 сен 2002
IC DAC 14BIT A-OUT 28TSSOP. 14 Bit Digital to Analog Converter 1 28-TSSOP. Data Acquisition - Digital to Analog Converters (DAC)...
THS5671AIPWRG4
866 ₽
Рутоника
THS5671AIPWRG4
THS5671AIPWRG4
Hi-Tech Circuit Group
THS5671AIPWRG4
Pin28
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)9.83 | 1ku
АрхитектураCurrent Source
DAC: Channels1
InterfaceParallel CMOS
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP)
Power Consumption(Typ)(mW)175
Resolution(Bits)14
SFDR(dB)75
Sample / Update Rate(MSPS)125
RoHSНе совместим
  • Evaluation Modules & Boards: THS5671EVM
    THS5671A Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital to Analog Converter > High Speed DAC (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5671AIPWRG4
