Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI LM22670QMRE-5.0/NOPB — Даташит
СерияLM22670-Q1
МодельLM22670QMRE-5.0/NOPB
Datasheet Texas Instruments LM22670QMRE-5.0/NOPB
3A SIMPLE SWITCHER, понижающий стабилизатор напряжения с синхронизацией или регулируемой частотой переключения 8-SO PowerPAD от -40 до 125
LM22670/-Q1 42-V, 3-A SIMPLE SWITCHERВ®, Step-Down Voltage Regulator With Features datasheet
PDF, 1.6 Мб, Версия: P, Файл опубликован: 28 окт 2014
  • AN-1533 Overvoltage Protection Circuit for Automotive Load Dump (Rev. B)
    PDF, 83 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report discusses an over voltage protection circuit for automotive load dump.
  • AN-1797 TO-263 THIN Package (Rev. A)
    PDF, 2.3 Мб, Версия: A, Файл опубликован: 24 апр 2013
    This application note describes the TO–263 THIN Package.
  • AN-2020 Thermal Design By Insight, Not Hindsight (Rev. C)
    PDF, 568 Кб, Версия: C, Файл опубликован: 23 апр 2013
    This application report provides an in-depth discussion of thermal design.
  • SIMPLE SWITCHER Regulators Take Over Automotive Applications (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Power management applications, typically located on the front line of the automotive electronics system,can be subject to wide input operating voltage extremes resulting from load-dump and cold-crankingconditions. Careful selection of the power management electronics can provide added margin andprotection to the automotive electronics system. The simplest design is provided by a power manage
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
LM22670QMRE5.0/NOPB, LM22670QMRE 5.0/NOPB
На английском языке: Datasheet Texas Instruments LM22670QMRE-5.0/NOPB
Публикации по теме
Политика конфиденциальности
