Datasheet Texas Instruments CAHCT1G04QDCKRG4Q1 — Даташит
СерияSN74AHCT1G04-Q1
МодельCAHCT1G04QDCKRG4Q1
Автомобильный каталог Один инверторный затвор 5-SC70 от -40 до 125
Single Inverter Gate datasheet
PDF, 215 Кб, Версия: A, Файл опубликован: 7 фев 2008
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBCS
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)75 Mhz
Gate TypeINVERTER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)8/-8 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingAutomotive
Schmitt TriggerNo
Special FeaturesDown translation to Vcc,low power,TTL compliant
Sub-FamilyInverting Buffer/Driver
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)7.5 нс
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
Серия: SN74AHCT1G04-Q1 (2)
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments CAHCT1G04QDCKRG4Q1
Публикации по теме
