Datasheet Texas Instruments REG1117FA — Даташит
СерияREG1117A
МодельREG1117FA
1A Положительный регулятор с низким падением напряжения 3-DDPAK/TO-263 0–125
REG1117: 800mA 1A Low Dropout Pos Regulator 1.8, 2.5, 2.85, 3.3, 5V, Adjustable datasheet
PDF, 846 Кб, Версия: D, Файл опубликован: 21 июл 2004
45 предложений от 27 поставщиков
Чип стабилизации напряжения, 800mA and 1A Low Dropout (LDO) Positive Regulator 1.8V, 2.5V, 2.85V, 3.3V, 5V, and Adj
REG1117FA
101 ₽
REG1117FA
109 ₽
REG1117FA-1.8/500
от 355 ₽
REG1117FA-1.8
Pin3
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
МаркировкаREG1117FA
Width (мм)8.41
Length (мм)10.18
Thickness (мм)4.44
Pitch (мм)2.54
Max Height (мм)4.83
Рекомендуемая замена
ReplacementREG1117FAKTTT
Replacement CodeS
Accuracy(%)2
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.85 | 1ku
Fixed Output Options(V)1.8
2.5
5
Iout(Max)(A)1
Iq(Typ)(mA)4
Operating Temperature Range(C)0 to 125
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)29
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)3DDPAK/TO-263: 155 mm2: 15.24 x 10.16(DDPAK/TO-263)
Regulated Outputs(#)1
Vdo(Typ)(mV)1200
Vin(Max)(V)15
Vin(Min)(V)3.7
Vout(Max)(V)13.8
Vout(Min)(V)1.25
RoHSНе совместим
  • An Easy Solution to Current Limiting an Op Amp
    PDF, 35 Кб, Файл опубликован: 2 окт 2000
    Many circuits today not only require voltage regulation but they also need current regulation. Some systems draw excessive current during power on, which can cause expensive system components to burn up due to improper powering of supplies. This is not the only problem associated with excessive currents. Some applications need to limit the current an op amp can provide to a specific load. This cir
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
На английском языке: Datasheet Texas Instruments REG1117FA
