Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 74CB3T16211DGGRG4 — Даташит
СерияSN74CB3T16211
Модель74CB3T16211DGGRG4
24-разрядный полевой транзистор, 2,5 В/3,3 В, низковольтный переключатель шины с толерантным преобразователем уровня 5 В 56-TSSOP от -40 до 85
SN74CB3T16211 datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 17 авг 2012
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаCB3T16211
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Additional FeaturesPowered off protection,Signal path Translation
Полоса частот100 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)5 пФ
Input/Output ON-state Capacitance(Typ)13 пФ
Количество каналов24
OFF-state leakage current(Max)10 мкА
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
Ron(Max)9.5 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)70 uA
Supply Range3.6 Max
VIH(Min)1.7 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
На английском языке: Datasheet Texas Instruments 74CB3T16211DGGRG4
