Datasheet Texas Instruments BQ24765RUVR — Даташит
| Серия | BQ24765 |
| Модель | BQ24765RUVR |
Зарядное устройство, управляемое по SMBus, со встроенными полевыми транзисторами 34-VQFN от -40 до 155
bq24765 SMBus-Controlled Multi-Chemistry Battery Charger With Integrated Power MOSFETs datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 ноя 2015
Купить BQ24765RUVR на РадиоЛоцман.Цены — от 111 до 1 045 ₽31 предложений от 18 поставщиков Микросхема Чип управления батареи, Battery Charge Management SMBus Controlled Battery Charger with Integrated FETs Battery Charger 8064mA 1.024V to 19.2V 34Pin... | |||
| BQ24765RUVR Texas Instruments | от 111 ₽ | ||
| BQ24765RUVR QFN34 TI | 420 ₽ | ||
| BQ24765RUVR Texas Instruments | 672 ₽ | ||
| BQ24765RUVR Texas Instruments | по запросу | ||
| Pin | 34 |
| Package Type | RUV |
| Industry STD Term | VQFN |
| JEDEC Code | R-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | BQ24765 |
| Width (мм) | 7 |
| Length (мм) | 3.5 |
| Thickness (мм) | .9 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Absolute Vin (safety rating)(Max)( | 30 В |
| Battery Charge Voltage(Max) | 19.2 В |
| Battery Charge Voltage(Min) | 1.024 В |
| Cell Chemistry | Lead Acid,Li-Ion/Li-Polymer,LiFePO4,NiCd,NiMH |
| Charge Current(Max) | 10 A |
| Control Interface | SMBus |
| Control Topology | Switch-Mode Buck |
| Number of Series Cells | 2,3,4 |
| Operating Vin(Max) | 24 В |
| Operating Vin(Min) | 7 В |
| Package Group | VQFN |
| Package Size: mm2:W x L | 34VQFN: 25 mm2: 7 x 3.5(VQFN) PKG |
| Special Features | Integrated FET,Power Path,Thermal Regulation |
| USB Feature | N/A |
- Evaluation Modules & Boards: BQ24765EVM
BQ24765 Evaluation Module for SMBus Controlled Battery Charger with Integrated FETs
- How to Review a Multicell Switching Charger SchematicPDF, 196 Кб, Файл опубликован: 21 сен 2011
This application report provides a checklist for reviewing a switching charger schematic and explains each item in the list. - Operating Fuel Gauge bq20z7x/8x/9x and SMBus-Like bq24745/47/65 ChargersPDF, 132 Кб, Файл опубликован: 6 окт 2009
The smart charger bq24747/765 is a high-efficiency, synchronous battery charger with an integrated input current comparator. This charger provides low component count for space constrained, multichemistry battery charging applications. SMBus input current, charge current, and input current digital-to-analog converters allow for very high regulation accuracies that the system power management micr
Серия: BQ24765 (2)
- BQ24765RUVR BQ24765RUVT
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
