Datasheet Texas Instruments LP8557IAYFQR — Даташит
СерияLP8557
МодельLP8557IAYFQR
Высокоэффективный драйвер светодиодной подсветки для планшетов 16-DSBGA от -30 до 85
LP8557 High-Efficiency LED Backlight Driver For Tablets datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 18 дек 2015
15 предложений от 12 поставщиков
IC LED DRIVER RGLTR DIM 16DSBGA. LED Driver IC 6 Output DC DC Regulator Step-Up (Boost) PWM Dimming 25mA 16-DSBGA. PMIC...
727GS
LP8557IAYFQR
от 2.32 ₽
LP8557IAYFQR
79 ₽
LP8557IAYFQR
26 227 ₽
Hi-Tech Circuit Group
LP8557IAYFQR
Pin16
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
МаркировкаD41
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов6
Duty Cycle(Max)100 %
LED48
LED Current Per Channel25 мА
Рабочий диапазон температурот -30 до 85 C
Package GroupDSBGA
Peak Efficiency93 %
Shutdown Current(Typ)0.001 uA
Special FeaturesCABC,Edge Rate Control
Switching Frequency(Max)1000 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)28 В
Vout(Min)7 В
  • Evaluation Modules & Boards: LP8557IEVM
    Evaluation Module for LP8557 High Efficiency White LED Backlight Driver with I2C Control
  • Evaluation Modules & Boards: LP8557EVM
    Evaluation Module for LP8557 6-channel High-Efficiency LCD Backlight Driver
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: LP8557 (4)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments LP8557IAYFQR
