Datasheet Texas Instruments TPS54226PWPR — Даташит
СерияTPS54226
МодельTPS54226PWPR
Входное напряжение от 4,5 до 18 В, синхронный понижающий преобразователь 2 А с Eco-Mode™ 14-HTSSOP от -40 до 85
4.5V to 18V Input, 2-A Synchronous Step-Down SWIFT Converter with Eco-Mode datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 25 июл 2011
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаPS54226
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Control ModeD-CAP2
Duty Cycle(Max)90 %
Iout(Max)2 A
Iq(Typ)0.8 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Power Good,Synchronous Rectification
Switching Frequency(Max)700 kHz
Switching Frequency(Min)700 kHz
ТипConverter
Vin(Max)18 В
Vin(Min)4.5 В
Vout(Max)5.5 В
Vout(Min)0.76 В
  • Evaluation Modules & Boards: TPS54226EVM-539
    TPS54226 Step-Down DCAP2 Mode Converter Evaluation Module
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
  • D-CAP2 Frequency Response Model, based on frequency domain analysis of Fixed On-
    PDF, 681 Кб, Файл опубликован: 2 янв 2013
    TPS542xx D-CAP2 Frequency Response Model, based on frequency domain analysis of Fixed On-Time with
Серия: TPS54226 (5)
На английском языке: Datasheet Texas Instruments TPS54226PWPR
