Datasheet Texas Instruments OPA27GPG4 — Даташит
СерияOPA27
МодельOPA27GPG4
Прецизионные операционные усилители со сверхмалым шумом 8-PDIP от -40 до 85
Ultra-Low Noise, Precision Operational Amplifiers datasheet
PDF, 967 Кб, Версия: C, Файл опубликован: 29 авг 2005
Микросхема Операционный усилитель, Ultra-Low Noise Precision Operational Amplifiers 8-PDIP -40℃ to 85℃
OPA27GPG4
122 ₽
OPA27GPG4
263 ₽
Контест
OPA27GPG4
411 ₽
OPA27GPG4
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA27GP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)100 дБ
CMRR(Typ)122 дБ
GBW(Typ)8 МГц
Input Bias Current(Max)8000 pA
Iq per channel(Max)5.7 мА
Iq per channel(Typ)3.3 мА
Количество каналов1
Offset Drift(Typ)0.4 uV/C
Output Current(Typ)25 мА
Package GroupPDIP
Rail-to-RailOut
Slew Rate(Typ)1.9 V/us
Total Supply Voltage(Max)44 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.1 мВ
  • Operational Amplifier Macromodels: A Comparison
    PDF, 59 Кб, Файл опубликован: 27 сен 2000
    All major competitors in the operational amplifier markets are providing their customers Spice-based macromodels. These models give the designer a tool to do initial characterization and a limited amount of system troubleshooting. In the interest of faster simulation times and lower CPU memory requirements, macro topologies have been developed to simulate a majority of the op amp's performance cha
  • An Error Analysis of the ISO102 in a Small Signal Measuring Application
    PDF, 29 Кб, Файл опубликован: 27 сен 2000
    High accuracy measurements of low-level signals in the presence of high isolation mode voltages can be difficult due to the errors of the isolation amplifiers themselves.
  • Level Shifting Signals with Differential Amplifiers
    PDF, 23 Кб, Файл опубликован: 27 сен 2000
    The INA105 is a unity gain differential amplifier consisting of a premium grade operational amplifier and an on-chip precision resistor network. The self-contained INA105 makes it ideal for many applications. One such application is precision level shifting.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA27GPG4
