Datasheet Texas Instruments CD74HC151EE4 — Даташит
Серия | CD74HC151 |
Модель | CD74HC151EE4 |
Высокоскоростной КМОП-логический мультиплексор с 8 входами, 16-PDIP, от -55 до 125
CD54HC151, CD74HC151, CD54HCT151, CD74HCT151 datasheet
PDF, 445 Кб, Версия: C, Файл опубликован: 13 окт 2003
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | CD74HC151E |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Полоса частот | 28 МГц |
Bits | 8 |
Количество каналов | 1 |
Configuration | 8:1 |
Digital input leakage(Max) | 5 uA |
ESD Charged Device Model | 0.75 kV |
ESD HBM | 2 kV |
F @ Nom Voltage(Max) | 28 Mhz |
Function | Encoder/Multiplexer |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
Тип | Standard |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 43 нс |
Бессвинцовая технология (Pb Free) | Да |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC151 (7)
- CD74HC151E CD74HC151EE4 CD74HC151M CD74HC151M96 CD74HC151M96E4 CD74HC151MG4 CD74HC151MT
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
